Oil Leak
Montana
I have noticed that my 67 has a pretty good leak coming from somewhere by the oil pan. I have the upgraded oil filter system and was windering if it could be coming from the woven hoses that run to the block. My oil pan has been snugged up a few times, so I don't think it is coming from there. It leaks quite a bit and is grimy on the drivers side of the engine block. Anyone ever have this problem?
I have had oil leaks from the pressure regulator gasket, the hoses, the fuel pump :rolleyes: gasket, and about everywhere else. Unfortunately, oil tends to travel, then pool, sometimes quite a way from where it exited. Plus, I find that if I am tightening my oil pan bolts, things often end up worse rather than better, because you're breaking what seals there were. Sad, but that's the case.
Probably your best bet is to clean things up, run it a short while, and try to find the origin.
I had leaks coming from the fuel pump and from underneath the skid plate on the oil pan, replaced both and then found one coming from the side plate on the block. The oil pan skid plate leak was the worst cuz I couldn't figure out where the oil was coming from. Sides of the pan were dry, but always oil between the pan and and skid plate. Pain in the ass!
Now with the new fuel pump gasket, pil pan and gasket and new side plate gasket, the leak went away, for now.
Just waiting for the oilnext leak to start.:grinpimp:
S/F
Kush
S/F
Kush
That is a favorite place for the oil pan to rust out. Crap gets trapped between the skid and the pan and traps moisture. I had to braze my pan, then I sealed up the gap with a sealant. No leaks yet.
I agree with IDave, that you should clean everything off with a pressure washer and then look for the leaks. Always look higher than you see the oil.
GL
Ed
That is a favorite place for the oil pan to rust out. **** gets trapped between the skid and the pan and traps moisture. I had to braze my pan, then I sealed up the gap with a sealant. No leaks yet.
GL
Ed
I just did an oil change on my 69'and there is a leak, just a few drops coming form the drain plug. I had to use a metal washer for the drain plug in stead of the rubber one. Could this be a cause? I tightened the plug pretty well, hopefully I'll be able to remove this later :) Just wondering how you sealed this area? Cheers!
The oil pan drain plug gasket is supposed to be a thick fiber gasket, not rubber, not metal.
It could very well be the source of your leak, as could the skid plate spot welds. It is not uncommon for the skid plate to corrode where it meets the oil pan, and weep from that area as well.
I've also found that the fan will blow oil every freakin' place over time....so I second that a good cleaning and then watching it carefully could show the culprit pretty easily. I did that and realized it was just the breather valve on the passenger side and the oil was blowing everywhere else. Yours is on the driver's side, I know, but could still help.
