Oil Leak Help
Little Rock, AR
Good Morning, I had a question about oil leaks and was wondering if you might have some insight. We have replaced the Dist o-ring, oil pump cover, crank shaft o-ring. We have wiped the engine down and from the looks of it, the oil is seeping out of this circular plug right above the oil/power steering pump where the green arrow is pointing to. Do you know what this is? The oil leak seems to be starting from this plug and dripping down. This has been very frustrating and any help you can provide would be great!
Thanks again,
Mike
I think I have a similar leak and it's nearly impossible to get a camera down there. I am assuming my leak is coming from the area since I replaced the front main, oil pump cover, and dist o-ring. The lower alternator bracket is covered in oil all the way down to the bottom of the oil pump cover. The bottom and backside of the steering pump also has some oil on it. My steering pump o-ring could be leaking because the oil isn't red. It's definitely engine oil. Or it could be the spot indicated above.
Anyone ever figure this one out? I have the same problem and when you reach back in there it feels like a large ball bearing in the hole the original poster pointed to in the illustration where it seems the oil is coming from.
