Oil Indicator BJ73
California
Am not sure if my oil indicator it's failing or thats how it works, but it's always indicating low oil, even after an oil change.. is there a better after market oil indicator that you guys recommend, or is does a fix exist? thank you in advance
Most Toyota oil pressure gauges as well as a lot of water temp gauges belong in a box of Cracker Jacks. I replace both with high quality aftermarket gauges as quickly as possible.
Do you guys have the part # for the sender? And where can I find it? Thank you
Its used on all Landcruisers and plenty of cars from that era.
You can use a north american FJ62 FJ80 or FZJ80 oil pressure sender 83520-60011 . Some have an earth contact ,some dont.
They dont die very often , Ive only replaced one on 4 landcruisers I've owned.
1934202
