Oil in distributor question
Lake Orion MI
Having trouble uploading pictures right now, but I went to change my distributor cap and found oil inside sitting at the bottom of the cap. Does this automatically mean I need a new distributor or is there still a chance I just need to replace the shaft O-ring?
If I need a new distributor, is an OEM used an option? Landcruiserparts.net has them available.
1996 with 184k.
indeed the dizzy-o ring - seals the dizzy to the block -
so when / if the "o-ring" fails - it will leak on the exterior....
oil inside your dizzy is an whole other issue (believe it was just covered last week)
and the general consensus was that the dizzy shaft / internal seals was NOT a serviceable part...
thus requiring a replacement....
Bf
Yep, doesn't sound good for your wallet. I danced a happy dance when I pulled my cap and found no oil in it.
First, how much oil, if it's not being flung around by the rotor, likely isn't hurting anything, clean it up and see how long it takes to return. Restricted breather and/or PCV can cause excessive crankcase pressure , pushing oil past seals that it wouldn't otherwise.
Here are some pics. Doesn't look like oil is being flung.
Also replace the distributor cap rubber seal. It can let in the oil from the outside as well. This one seals the cap to the housing.
Use electric motor or electrical contacts cleaner.
I don't recall on the P/N. Check the toyotapartsonline.com.
