Oil in coolant
I just flushed the coolant from my 97 FZJ80 (radiator and block). It has around 135,000 miles. The coolant was not too bad. I will have to go back and see when I did it last. One thing I noticed this time, was a VERY slight sheen of oil in the drained coolant (primarily from the block). I am talking a VERY minute amount. I know water in the oil is bad, but would anyone be concerned a slight sheen in their drained coolant? Thanks in advance....
Now that I think about it, the oil sheen was seen in the coolant on the ground, not in the bucket. I am guessing some oil was picked up from the block. She has a little oil on the block from the oil pump seepage. I think I figured out where the oil came from, but just in case, would a small amount of oil in the coolant be bad?
Yes. A small amount would indicate you'll soon have a large amount. However, I've seen the same sheen in coolant as it's hitting all manner of underbody stuff with road grime, oil and grease on it. Not to worry unless you have other evidence such as a sheen in your overflow bottle or radiator, or light peanut buttery looking deposits under your oil filler cap.
DougM
Your guess that the oil came from the stuff on the outside of the block is probably right. If you're really worried about it you could always send am oil sample for used oil analysis to see if there's any coolant in your oil...but I think you're worried about nothing.
x3, could be something, probably nothing. Unless you see more symptoms, I wouldn't worry about it.:meh:
Thanks for the replies. I might send a sample off. We are getting ready to drive about 3000 miles, so we will see if it is anything more than oil off the block
Better get on the stick. Takes a few days to send it and then a day or two for them to post results...Also, you can get on their website and they'll tell you how to send them a sample without waiting for their sample kit to arrive.
DougM
