Oil gauge question
When I start the car in the morning the oil gauge jumps up to 2/3 of the gauge and slowly comes down. I just got the car a few weeks ago and wanted to know if that's normal. Then at idle when I'm parked through out the day this is what my gauge reads.
I figured. The other day it was cold and rainy here in Los angeles. Started the car in the morning and did the same thing as you described. Oil light came on and oil pressure went to high to the 2/3 line then slowly climbed down. Is the gauge supposed to be that low on idle?
Thanks to both of you. Do you guys notice a funny noise when driving? I can't explain in. It goes away after a little bit of driving after start. I can only explain it as a weezing noise. Sorry. I know that's hard to explain
That's very normal but you might want to double check your oil level.
Just an FYI, oil level in the crank case has nothing to do with oil pressure, unless the oil level is so low that the pump pick up is sucking air. If that's the case you may have other issues ;)
