OK...so here is my saga. I have a rebuilt F engine (past warranty date now
) that I blew a front oil galley plug out on (and yes it was a metric plug). Fixed that, seems as if it just wasn't dimpled...Now 300 miles later I have a rear main leak with radial streaks on the flywheel and all. I have dropped the rear of the engine, removed the trans/tc, and even ended up rebuilding the tc. My question is knowing the history of the front plug not being installed correctly would you go ahead and replace the rear oil galley plug and cam plug along with the main seal? I have done lots of searching on here and seen some references to taping the hole to eliminate future probs, any advice?
Thanks
IDoc
Thanks
IDoc
