Oil Filter Question – Newbie
Portland, OR / SW WA
Hi, all! I had a question about oil filters... I am going to have my father change the oil on my rig sometime next week. Is there a certain oil filter that other 80 owners would recommend? I have a '94 Cruiser. I didn't know if aftermarket filters were acceptable, or if I should go for OEM or Toyota brand ones. Thanks for the help!
Buy a case of the OEM ones on Ebay for about $45 shipped for 10 and keep your Toyota a Toyota.
Label the box when you get them "Land Cruiser"
This keeps you from swearing; after going to the store for a <$5 item.
I buy oil by the case/jug as well.
Oil changes are done in 15 mins, and I have yet to wait in line.
Not sure what your time is worth, but I do know it is finite?
Mitch,
The choice depends on your vehicle use: around town as a daily driver, or full time off-road? The filter's ability to remove particulates in the 10-20 micron size range is the most important (because that's near the limiting size that can't fit between your rings and cylinder walls). Even brand new seals can't seal against all outside contaminants, parts wear and become particulates and new oil isn't clean. (So if you're changing your own, filter it first. Two coffee filters, stacked,will do the job.)
Wix filters are generally specified as OEM for heavy equipment for good reason. They put the same effort into design and manufacturing for passenger cars and trucks that they do for the big stuff.
That said, Amsoil recommends Wix, Mann and Donaldson. (AMSOIL Ea Oil Filters - Nanofiber Technology) They should know, they make the best oil you can buy (IMHO). They also recommend changing your oil only when it's dirty. Your odometer doesn't know when that is. Something that is used in the heavy vehicle industry, and IMO is cost effective in the long-run is oil sampling and, for people who just can't get enough new stuff, engine oil bypass systems (By-Pass Oil Filtration).
HTH
Rotella 5-40, Toyota, wix are good I usually go with the Napa gold 1515 and a new drain plug gasket.
