Decided to change the oil today. Drained the oil, pulled the old filter, cleaned the gasket surface on the block, put a little oil on the o-ring on the Toyota 15600-41010 filter and installed hand tight. Added oil, took a test drive and the filter had a slight drip.
Removed filter, cleaned gasket surface on block (made sure old o-ring was not there), cleaned filter, oiled o-ring and installed hand tight. Still had slight drip.
Repeated process again only this time I grabbed a new 15600-41010 off the shelf and installed hand tight. Still had a slight drip.
Grabbed oil filter wrench and tightened filter a little more than hand tight. Drip gone but a bit of oil is still seeping out.
I'm pretty sure the gasket surface is clean and I've never noticed any leaking before. I'm going to pull the filter again in the morning when all is cold, clean and reinstall and see what happens.
Any suggestions?
Thanks
Tom
Any suggestions?
Thanks
Tom
