Oil filter housing question
Fayetteville, GA
I have a new to me LX450 and was going over it yesterday making a list of everything I need to buy for it to fix the few little problems I found. After noticing the engine oil filter housing was loose and would move front to back I tightened the bolt holding it to the engine. After this it leaks like crazy.
Here’s my question, what serves as a gasket between the oil filter housing and the engine? O-ring or some other type of gasket? I went to NAPA and got no help on this and I live a good ways from a Toyota or Lexus dealership. Would really like to have the parts in hand before I take it apart.
Not sure what you have on yours but the 4.5l used in TLC's and LX450's uses a spin on type oil filter, not a housing and canister. Someone may have replaced yours with such a setup - I don't know. But if it was me, I'd remove it all together and see what it takes to reinstall the original style filter.
To be clear, this is the housing I am talking about. The big bolt head above the oil filter is the one I tightened and then it started to leak. Just trying to figure out what I need to fix it before I pull it apart.
That's not a stock US 1FZ-FE setup. The OEM screws into the block, at 90°. There's a seal around the lip of the oil filter. Oh, and I'd use a Toyota filter too. They're cheap and they fit like they were meant to be there.
Mine isn't OEM, I inherited it from the PO. I have a replacement on the shelf, waiting for the next oil change.
I'd guess you'd want to remove the 90° cast piece and reinstall (if it's been removed) the union @Tedward mentioned. That should solve your problems. If you want to keep this setup, you'll need to take it apart to find the problem. I wouldn't think it would be difficult.
No telling how this contraption got on the engine, will take the old girl back to stock.
You are correct on the Toyota filter, this is how I got the truck just a couple of weeks ago.
Thanks guys for your help on this! Who would be the best person to call for Toyota parts on line? Would like to use a vendor here as it is a haul to a Toyota dealer from my house.
