Oil Filter Help
Oil Filter Help(edited with pics)
What brand of oil filter do you guys use? The reason I ask is this past weekend my dad changed the oil in his LX450 he went with a Fram Oil filter specified in the Schucks Fram Oil filter catalog you find at the store in the filter isle. Today he called me up saying there is a small pool of oil under the LX and it seems like its coming from the acces hole to where the engine and the tranny meet. Now I asked him if the filter he got was small he said yes almost more then half the size of the Penziol one that was on there.
Does it sound like due to the filter being smaller oil pressure was raised in the engine and it is leaking out the crankcase bearing or is it all blown out and now needs a new one...or if he puts the larger one one this will go away?:confused:
Thank you for the help!
Jerry
:crybaby: :crybaby: Why do we even bother to write FAQ's????
Tell your daddy the Fram is the best filter in the world. He should use them on everything.
Jerry,
Many of us consider the Toyota '20004' filter the best available. They are spendy but you can order a case or 2 from CruiserDan. There is an oil & filter section in the FAQ where the topic of oil filters is covered very well. FYI, the FRAM filters are among the worst you can use on your 80.
As for the oil leak, we can only speculate until you can get us more information; perhaps a picture of where it is leaking. It is quite possible the FRAM has failed or the seal is bad. These are problems with low-tier oil filters. The '04 filter is a small filter so you can't generalize by saying Small=bad, Large=good. Size doesn't matter (counter-intuitive, huh?) What matters with oil filters is the filtering material and the construction and design features (e.g. anti-drain back valve.)
-B-
even though fram filters suck ass I doubt it would cause an oil leak where you described it....
ps tell your dad to get mobil one, purolator, toyota or wix filters 4 of the most highly reguarded filters on here
Just got back from my dads...so heres some pics. Also the plastic cover for the flywheel is mising on his truck.
The fram took some persistace to get unscrew!:mad:
There was a large deposit of oil inside the large opening . My dad says he looked the rig over well and the bottom of the rig was dry and oil free so this is fresh!
Any guess as to where the oil would be coming from?
Thanks Guys,
Jerry
wipe down what you can, put a good filter on, fill up the oil, then start the truck and see what happens. A leak that bad you'll see right away.. but my money's on a bad fram install.
Any chance the gasket from the previous filter got stuck on the block? wipe that area real clean before installing the next one.. then read the oil faq :rolleyes: :)
The leak is not coming from any where the engine the picture above is of where the Engine and Transmission bolt toghether. That is where the oil appears to be coming from and the only thing i can think of it being would be the rear main oil seal!
Any chance the gasket from the previous filter got stuck on the block? wipe that area real clean before installing the next one.. then read the oil faq :rolleyes: :)[/quote]
i ran into this for the first time last night on my 4runner and had about 5 quarts of fresh oil on the floor, fresh oil doesnt clean up like old dirty oil and it sprayed all over the exhaust so now we make a small smoke shield
Define "oil leak" if your talking about that "pool" under the truck in the picture, I doubt that it's from the rear main. Rear mains seep and overtime will drip, but it's very rare to have one "blow" there isn't any pressure in that part of the motor to drive oil out.
I have seen oil filters leak and shoot a stream of oil across the engine compartment, making it look like somethings leaking a longway away from the filter.
