FJ40Jim said:Taco,
If #4 is a molded hose, exactly as pictured, then the OEM molded hose should be used.
As noted above, make sure the temporary repairhose doesn't kink shut.
But, if the oil cooler in question is from a late 1980-newer, then the bent section of #4 is replaced by a formed metal pipe, similar to #7 in the pic. In that case, the #4 connector hose is just an 8" piece of straight 5/8 heater hose.
Now get your junk fixed so we can wheel!;p
Poser said:Rice...
It does not have oil flowing through it....only coolant.![]()
Poser said:Rice...
Don't listen to that guy...he has no clue most of the time... ;pphishtaco said:I heard Nick say once "Marty you should get all new hoses for that oil cooler, those look original."
I'll try Napa tonight.
