Oil Consumption Catch Can Results
North Front Range, CO
Now that I have a Supra I don't get to drive the 80 to work anymore.
I do have the results from 1435 mi driving on fresh oil change with syn RotellaT.
I am down 1/2 qt but there is only about 3 tablespoons of oil in the catch can.
I got a couple table spoons from the old oil after less than 100 mi.
My consumption use to be 1qt for 3000 mi then the consumption would be 1qt for 1500 mi, 1 qt for about 1000 mi etc.
This winter it went to 2000 for a qt, then 1000 for a qt, 800 etc.
It looks like most of the oil is going past the rings.
But when the oil was oil I was getting more oil past the PCV.
Different engine but when my 3FE had a bad #5 cylinder (20%+ leakdown all other cylinders at 5%) I got about 1/2-1 tablespoon out of the pcv per fillup (I also had a catch can in the pcv line). It was worse around town than on the highway (mostly light cruise).
I am at 2000 mi on oil change and oil is down 1qt.
The amount of oil in catch can is several table spoons so oil must still going past the rings.
The motor is not as strong as it use to be.
I think the loss in power started about the time the oil consumption changed from 3000 mi/qt oil to 2000mi /qt.
Did compression last month:
Cyl Dry Oil
#1 155 165
2 155 165
3 155 165
4 155 170
5 160 180
6 165 180
#1 2 3 spark plugs were clean
#4 5 6 were black with carbon
Is there a way to tell if there is stuck rings and how can I free them if some are stuck?
Could excessive oil through the pcv cause stuck rings?
When I installed the catch can I had CE codes 25 26 rich and lean air/fuel mix.
At same time I cleaned up all the ground connections.
The CE has not returned.
Don't know if there was a ground or oil fouling through the pcv that was causing the CE problem.
I have about 6000 mi on my oil and the oil in the catch can has not changed.
My oil consumption is 3qt for 6000 mi.
I replaced the failed O2 and decarboned the motor with Seafoam.
There is more power but still not as strong as is once was.
You should have done both O2 sensors just to baseline it. (I take it you changed only the one for cyl's 4-6.)
1/2qt per 1k miles is nothing.
BTW; when did you get the Supra?? I must have missed that. All I remember is you wanting to try every snake oil mileage trick in the book (by way of multiple threads), us telling you to get a different vehicle for your commute, and you steadfastly refusing! :lol:
Cheers,
Curtis
Got the Supra several month ago. Good thing I got it as the 80 is old, tired and broken.
Its nice to have a back up vehicle...Just can't wait for parts for the Supra so I can get it back on the road again :o
Good thing the wife has a Camry.
I replaced both O2.
I still would rather drive a 80 on my commute (h8cars) but the Supra is about the only CAR I will do that commute in.
An oil catch can is not stock. You have to install one between the PCV valve and intake plenum.
