Official Wagon Build Up
More Pics
Shes gonna be tall:bounce:
DHONDAGOD said:
how much beer before you finish??
carry on..
:grinpimp:
Looks good man, I can't wait to see it and check out your fab. Hopefully Ill be at the Roundup, if not then July 4th for sure. Ill be PMing yah agin soon, finally finished my axle jig and about to cut and turn the practice housing. :cheers: :beer: :beer: :beer: :beer: :beer: :beer:
you should weld the hatch back on for the rear not use plexi
The bulldozer blade is goin on the wall of the shop, which construction commenced on yesterday. The gears will be later when all the suspension is fabbed. Got the bushing and shackle fabbed for the left side today. :grinpimp: Josh
These beeitches are gonna flex:bounce: and I probably will be trimmin more off the front of the fenders and lower valance Josh
Pics didnt load I'get some up tomorrow
Looking good Josh.
the Roundup is creeping closer...
GET BUSY!!!
Got the front axle mocked up under it, to make the pinion set where it needs to be the whole mess sets 2 7/8'' to the left. This makes the RH wheel look real good in the fender, but the LH looks stupid:ban: What to do?? After lots of deep thought and heavy drankin I'm gonna cut 2 7/8'' out between the spring pad and knuckle on the left side then sleeve it and weld it back together this weekend:D anyway if Nolan reads this, I may need some sort o calming pills or somthin before I go to hackin on my axle:bounce2: Josh
Couplea more. One of em really shows the 2 1/2" the axle sits forward. Josh
Gawd knows I ain't much on the technical aspects of this hobby ....
but it seems to me the only solution at this point is to throw out the one-ton stuff and go with Rockwells. :grinpimp:
:flamingo:
DavidW said:
Why not just outboard the springs? Save having to have an axle shortened and then not have a spare.
That would move the pinion over under the frame rail on the right side. Plan is to have both the chrom-moly and the stocker shortened so I will have a spare. Talked to Harold today, he can machine the dually hubs down so I wont have to buy the single wheel stuff:bounce2: Josh
