Unfortunately It has been well documented over and over in this and in many other forums (and you can do all the search here to validate it) that unless a lamp reflector IS designed from zero to carry HID bulbs, you are wasting your money.
The only non-HID bulb lamp type that barely pass a HID upgrade are the projector type and again this has been well documented that you should use a good projector lamp.
HID kits cost are way cheaper this days because most if not all are low quality asian sourced which had a unexpected expiration date either from the bulb or the ballast, neither of them last more than 2 years and usually burn before 3 or 4 months has passed.
The only HID kits worth are made with Bosch, Hella or OEM Japanese car manufactured ballast and bulbs, PERIOD. Let this HID kits for the street modded cars.
4 wheeling on dark off roads is not a joke and you can't afford a burned ballast or HID bulb. Replacing a simple quartz halogen bulb is very easy and they are so cheap that there is not a excuse to carry spare bulbs in the glovebox.
Even then it make more sense to upgrade your stock headlamps and if you are not satisfied with the improvement then go and add some high quality lamps. If you opt for HID ( which are great and I like them a lot) then buy one that born with a reflector designed for HID bulbs like the Hella's.
I'm not sure if this is directed at my post, but if it is, I have to respectfully disagree.
What I did was install HID H3 bulbs into off road IPF lights, which are only used as off road lights, not as driving lights against other traffic.
I spent a lot of time "web researching" retro-solutions ballast and bulb kits. I have yet to find a single person who has had anything bad to say about the kit, who actually owns one. And they are very popular. The seller actually sells OEM Japanese Matishita kits and Hella kits as well. The ballasts in this particular kit are neither one, but have proven to work just as well, as least so far. The ballasts are very comparable to the Matishita version in how they are designed and the internal potting for waterproofing and durability. They are not your typical Chinese junk, from what I've read and seen for myself.
I was skeptical too, but before you underestimate how much output these lights actually put out, even with a lower end IPF reflector, I suggest you see it for yourself first. As far as reflector, most of the posts regarding reflectors have to do with OEM headlight reflectors and how the HID output and bulb filiment orientation overwhelms the safety features built in the U.S. spec DOT reflector, which is suppose to protect on coming traffic. None of this matters for an off road light.
It's possible than an HID specific reflector that is designed specific for bulb orientation, might be more effecient, but I haven't a seen a major different in reflector designs between HID off road lights and halogen off roads. Even so, the output is so dramaticly improved that if the reflector is not being 100% effecient, it's many times better than any halogen light I've ever seen and at fraction of the power usage.
I agree that it's hard to say about longevity and I guess I'll have to be the guinea pig on this one. The lights and ballast have a lifetime warrenty, which of course only means anything as long as the seller is still around. If I can get a couple of years out of these bulbs and ballasts, I think it would easily be worth the cost.
For someone in a remote part of the world, where getting parts might be difficult, I could see recommending simple halogen H3 bulbs instead for ultimate reliability. If I lose my lights, I have back ups. Besides if I really needed to, I can simply pop out the H3 HID and pop in an H3 halogen that I have my spares kit.
