OEM Wiper blade length?
New Mexico
My rig has aftermarket blades, and I noticed while researching threads on this that the DS and PS OEM blade have two different numbers. Both front blades on it right now are 18", and the rear blade is 17", which seems a bit long. What are your OEM blade lengths?
-Eddie
I don't believe it's length that makes the difference, IIRC they are right and left blades. There might even be a top and bottom to the blades. All I know is that your truck will turn directly into the nearest ditch if you don't use OEM. :D
Never mind, I guess they are different lengths.
-Spike
On mine they are, D 17", P 18" and R 16".
driver side blade and insert part # 85222-1G080 list $19.94 and paid $11.99
passenger side blade and insert #85212-16120 list $16.30 and paid $11.99
Might have done better with "smart shopper" pricing, but was in a hurry and went to the stealership one mile from my house.
I don't understand... The driver's side is shorter but more expensive? Tools, are yours OEM?
-Eddie
The fronts are 450mm (both sides) and the rear is 400mm.
-Eddie
Yes, from Dan, I guess I cant read a tape, he would have the correct numbers.:o:D
Go get OEM blades. They're no more expensive than aftermarket and way better than just about anything else out there.
I agree 100%. Just replaced all of mine with new OEM and couldn't be happier. I've tried a lot of garbage aftermarket blades over the years. Don't waste your time or money.
And I thought I could trust you! BASTAGE!
-Spike
After much stress and :o, I went out and remeasured, more carefully, Drivers 17 3/8", Passenger 17 3/4". I got them from Dan, but ordered several different sets for the fleet of junk and probably the incompetent installer put the wrong blade on the wrong junk.
I would rant and rave about how great the factory blades are, but our climate isn't the best test. It rains and you realize that the blades are shot, order and install new ones, a year or so later it rains again and you realize that the blades are shot.....:D
I will say that they priced right and fit well, if you can find a competent installer!:eek::D
-Spike
Dudes, that's funny! Thanks for the info.
-Eddie
<<<I would rant and rave about how great the factory blades are, but our climate isn't the best test. It rains and you realize that the blades are shot, order and install new ones, a year or so later it rains again and you realize that the blades are shot>>>
What climate allows for more than one season on a set of blades? In Maine I replace them twice a year: every spring, and every winter. Gotta run winter blades in winter.
m.
I run 500's up front. I didn't like that 1940's look for the wiped area. The DS, under high speed or high wind conditions, may sweep over and nudge the weatherstrip. But the overall wiped area is much improved (to these eyes, anyway!). :D
Exactly... I guess I could keep a new set in the glove box, then install them if I ever need to drive when it's actuality raining. The way it works around here, it would stop about the time I got the first one on, then I would be the idiot putting on new blades in the sunshine and by the time it rained again they would be junk!:D
... Gotta run winter blades in winter.
m.
Around here they are worthless devices about 99.9% of the time, year around, damn sunshine.:mad::D I have built a couple of mostly daily drivers that didn't have them, no blades, arms, motor or holes to mount them in.:D
-Eddie
18"drvr 18"pass 16" rear
-Eddie
18" driver 18"
The cheap ones from Toyota are made in Thailand. Sold with the blade and rubber as a disposable unit.
The originals from jpn you can simply replace the rubber.
2007......to just before 2019 haha Glad we finally cleared that one up.
