I just replaced my 94 stock radiator (pinholed) with a new OEM brass one from Cdan. I also threw in a replacement Thermostat(oem also) and notice that the stock temp guage rises significantly more before popping off than the one it had replaced.(which was oem also).
Basically the older thermostat resided slightly shy of the midway point as is common from what others position. The new one however moves to a position thats noticably higher than the halfway point by about the same distance that the old one was lower than.
I know the stock temp guage is woefully imprecise.........but given that both thermostats are the same what could be the source of this variation? possibly thermostat variation? How accurate are thermostats from unit to unit? has anyone else experienced thermostat variation? or could this be something like variation in % of distilled water to coolant ratios effecting this. ( i tend to run 60/40 but with the amount left in the block even after drain...i figure this could vary some)
