OEM swing out tire carrier install
I was talking to someone from Japan via IG the other day and they were asking how to install a factory tire carrier when his 80 didn't come with one. I am glad this thread came back to the front page, I sent him the link to this thread.
View of brackets and carrier for fitment.
The long bolts go through the inner D pillar for the top fitting as most of the load is there when it is open.
I can hang off it when it is open with no affect/deflection. I’m 185lbs.
Nutserts are inserted with epoxy thickened with milled fibers then set. After they are installed they are once again potted with epoxy and milled fibers.
Cheers
1 set including necessary hardware, currently available.
PM for more info.
I made a few holes n the inner D pillar for the 2 through bolts.
Also, when your working in that area put some rags to fill the hole so if you drop things they drop to the lower bowels f that area. If you do drop you need to remove the lower plug underneath truck to access the fallen items.
