OEM replacement for front door checks
I used these:
68610-60040
From 70-series, IIRC They were about $40 USD when I bought them. I think they're identical to the 35030 listed above.
FWIW, the pin that fits the hole in the end of the limiter is still available, even in the USA. Mine were very worn.
Because I wanted to know, I looked up the small parts, too.
I believe the pin is 68617-90A01 and the bolt(x2) is 90119-06312 for my ‘85. Both available domestically.
*edited to reflect correct pin part number per Spike Strip
So, I bought 2 of both the 68610-60040 (70 series) and the 68610-35030 (Hilux).
The 70 series door check is about 3/8” shorter than the Hilux one. Otherwise identical. While looking at the rear door of my ‘85 60, I noticed the door check has a little bend to it. I’ll have to see if the length matters in the rear.
Bolts and pins came too. Ready for a little refresh!
So, I bought 2 of both the 68610-60040 (70 series) and the 68610-35030 (Hilux). View attachment 4100740
Please advise if youn find the one for the rear please. Thanks mucho
Do the new pins come with the little brass clip that locks them on? I seem to have lost one last night putting on new door weather stripping.
