OEM quick connectors
Shippensburg PA
Website
www.iluvrocks.com
has anyone come up with a source for the OEM wiring harness connectors?
(mainly 3 pin, 4pin, and 6 pin)
I'm fairly certain that the spade connectors in them are AMP connectors, but I can't find a source for the nylon connectors. I've been searching the archives, and what little I come up with doesn't have answers.
I thought I would throw it out again and see if anyone has found a source :confused:
Chris, I found some at Radio Shack. 2-3-4-6-8 pin.
GL
Ed
You might also try waytekwire.com and search around there.
Radio Shack!?!?!
really? and they're the same (or work with) the OEM connectors?
believe me...... you wouldn't BELIEVE the number of electrical suppliers I've been through :rolleyes:
I'm very close to showing up on the doorstep of AMP corporate (in the Harrisburg PA area) and going " TELL ME WHERE TO GET THIS CONNECTOR!" :D
No, they won't work with OEM connectors. I just bought male and female for what I needed. At the time I was making up a loom/harness for an overhead console and wanted to be able to D/C when I took off the hardtop.
If you are doing a resto, I have seveal harnesses that have lots of connectors. PM me with what you need.
Ed
Go to a junk yard that has lots of older 70's Toyota cars and trucks. The connectors are the same. Cut what you need out of the wiring harness's and splice them into yours. A much better alternative (if you don't have to be stock) is to start replacing stock connectors with Weather-Pak connectors. Available just about everywhere in 2.4.5.6 pin versions. www.waytekwire.com for a good source.
I don't know about availability of 40-series parts, but ask your dealer if he has the Wire Harness Repair manual, publication RM767E. This manual has part numbers for connectors and replacement pigtails (the metal connector with a short piece of wire attached). Oh, and it's not inexpensive, but it is OEM. My closest dealer didn't admit to having the manual, but he did pull out a "repair kit" that had a bunch of miscellenaous parts. I went to another dealer and he had the maunal and let me look through it for the right parts.
I talked with John Hocker who sent me his PDF's of connectors (maybe the same manual?) and we couldn't find anything.
I found a 4 pin connector in it that *looked* right, but the part number came up at $.17 retail....... led us to believe Toyota hasn't updated the price in quite a while. We placed an order from Japan, but aren't holding our breath. BTW, only the female end came up.... male end discontinued.
I'm re-doing my harness with weatherpack, but when it comes to all the dash switches and such, you just can't change them easily.
That's interesting. I wonder...
Hey Landpimp, do you have that pub?
