Oem Pto Winch
stephen said:
Hello there!
this is stephen form philippines, and kindly please advised me with the OEM PTO winch for my 1969 fj40 cruiser, does all OEM PTO winch desame?, is it compatible to all models, coz i found a OEM PTO winch from a 80 series cruiser will it match with my fj40
TNX MAN,
pls give me a shot
Hey Stephen, you might be better served to post this question in the tech section pertaining to the 40 series, this forum is for the new FJ-Cruiser.
To answer your question, I do not believe the winch heads (part with cable drum) are the same. I do not know for a fact but cannot imagine they would be.
I know for a fact that the PTO drive unit that bolts to the t-case will not be the same. No hope of that part working correctly.
Now, with a lot of ingenuity it may be possible to massage an 80 series PTO to work with a 40 series drive unit.
Hi Steven
Ill give you a shot hehe. So does your 40 transfer case have the PTO drive unit on it? If so you could just make up some sort of adaptor to the 60 series PTO drive shaft and forget about the 60 series drive unit. I doubt the 60 series winch would have the same mounting as on your 40 series but itd be pretty easy to fab something there too. Hope that helps, let us know how it works out.
It depends on what transfer case the Phillipine '60 series trucks came with. Here in North America they all came with split transfer cases and those are NOT compatible with the older PTO's (the PTO looks very similar but bolt patterns are different). If it came with the J30 transfer case, known here as the single piece transfer case, then yes it should bolt up no problem.
The early '40 series transfer cases are single peice cases and go by the code number J30. The split case is larger and was only found on the latest '40 series and versions of the split case are still in use today in the newer 'Cruisers.
If all 6 bolts match then I'd bet the '60 series had the single peice transfer case.
If the case on the 60 is significantly and obviously larger than the transfer case on your 40, that means the 60 has a split case and your 40 has a single-piece case and hence the PTO drive unit off the 60 will not work with you case.
That is a smokin price. I bet it would easily bring 4-5 times that in the states.
If the bolts match up on the PTO drive gear to the PTO output plate on the side of transfer case it will work.
I put a 60# PTO on my BJ42. My transfer case is late model split case, the bolt pattern is the same so it fit.
Some of the earlier FJ# models transfer case have different bolt pattern and so the PTO would not fit - and it is easy to spot the difference in pattern.
Good luck they are a great winch!
