OEM overdrive switch?...
LOS ANGELES
Website
www.destechservices.com
There is a blank tab on the handle to change gears that seems to have been for an overdrive switch. Was there such an option for my 80? It would be a big help for when I have to tow up them hills.... to keep the tranny from shifting too much....
if so... is the wireing be in place for the switch?
You have a "switch" already: 3rd gear.
It's only a 4-speed tranny. Every gear is available on the shifter, from 1st to 4th (L-2-3-D)
ok but how bout when you lock up in fourth..... I could gun it and still not hit overdrive. when I pull back from the pedal...it drop another 2000 rpms.... I would think that that is overdrive.... Oh well....
"D" is overdrive. What you're describing is the torque converter locking up. When it locks up, the engine speed will drop around 200 RPMs.
Example: 2000RPM to 1800RPM @ 50MPH.
AFAIK, there is no way to control it in our transmissions (A440F).
Is this what you're talking about missing? (OD button is depressed--off--for better visability.)
Sorry about the crappy cellphone nighttime pic.
