OEM muffler best?
Guys,
My 96 80's exhaust seems to be getting a bit louder than when new.
No obvious holes or unusual exterior rust, do not know
if these fall apart internally; anyone ever pull one apart?
The pipes are fine, front and rear, just not sure if the resonator
is still working or not; I have the jet engine take-off whistle many
of us know well.
I want to keep a quiet exhaust, not into booming
Thoughts on muffler replacement; stick with OEM?
G
Nah.
Exhaust components are some of the only parts for which there seems to be no reason to stay OEM. Plus the stock components are PRICEY!, even by Toyota standards.
Get something that won't stick out from under the frame so much. Any muffler shop should have lots of options, and you'll probably be pleasantly surprised by the prices.
Curtis
I haven't heard of anyone replacing their stock muffler with an aftermarket one while maintaining the same level of quiet. I personally would stick with the OEM one and will once I need a new muffler. It seems that all the aftermarket ones are louder. I could be wrong, but I haven't heard it yet.
the stock muffler is definitely the quietest. I wish I had gone this route. If you have a dealer install it it has a lifetime guarantee I think.
Actually, I forgot about the dealer warranty on a replacement OEM
muffler, if as you say they still do it.
I have an OEM dealer installed muffler on my FJ62; it has been replaced at least once under that warrantly! Have owned my 62 since it was born; with 4 miles on the odo.
Problem is, those darn dealers charge just so much nowadays;
you know the drill; probably 1.5 hours by the book to install, a charge for disposal of the scrap iron, environmental fees, shop rag fee, utility adjustment fees, etc,etc,etc. It just hurts me to pay it.,
and I can afford it.:frown:
g
Wow; I stand corrected! :o
If anyone has an old one laying around, how about taking a bandsaw to it lengthwise
and posting pics?
Heck, the muffler is 12 years old with 240K on it; that is good even for a high grade stainless exhaust, I think.
If I change mine I will try to get it cut open; just need to find a band saw big enough!
g
Nah.
Curtis
I agree the prices for OEM are high, and aftermarket are less;
but most AM just do not last, except for a Borla (about $500 cat back).
However, some people tell me the Borla is significantly louder that OEM.
I like the quietness of the OEM; some people had previously commented on how quiet the engine is, even with the hood open.
I frequently travel long distances for 8-10 hours per leg;
want to keep stress on the ears and resonance (effects) on the body to a minimum.
G
I may be the loan dissident on this, but I purchased a Bosal OEM replacement muffler last year and I could not tell a change in noise levels from factory. I buy just about everything else from Toyota/Cdan. I also wheel my junk and I don't feel so bad about putting some marks on it. If I had shelled out the bucks for a Mr. T muffler, I wouldn't feel right about wheelin it. I guess it just depends on what you do with your rig. As a previous poster mentioned, if you wheel hard, you should definitely take a look at a custom fab job, which I priced and was surprised at how reasonable the quote was. I purchased mine from the link below and I was impressed....bolted right up and free shipping as well.
http://www.autopartswarehouse.com/search/?N=11780+1725+4294967008+9164
The OEM muffler is the source of the 1FZ whistle, personally if I were going to replace my muffler i would look for something else
Mine still has the whistle and I don't have anything OEM in my exhaust except the header.
I will say that my OEM exhaust lived for a lot longer - my cheap welded up exhaust lasted me 3 months and the muffler is cracked and two mounts have ripped off. Probably the fault of the guy that did it though.
Stick with OEM if you want them to be quiet.
I just went back to OEM muffler few weeks a go for same reason.
Guys,
...I want to keep a quiet exhaust, not into booming
G
Bosal is almost the same as stock as far as noise. Not made as good but much cheaper and pretty much a bolt on replacement.
Hoping to get a few more ideas before I make the jump.
Bosal's got a couple of votes; about $100 less then OEM, but
more cheaply made, maybe about the same decibel level.
Now, if only we all had decibel meters we could measure the sound levels both inside the cabin and outside, idling, highway speed,
etc.and post them.
:idea::idea:
Just would need some volunteers to hold on the roof racks at 70mph to get the outside measurements. :doh:
g
Gray,
In the past, I've used a magnaflow muffler as many recommended. The drone on the highway was awful.
I then tried one of those generic muffler that local muffler shop installed. Again, way too loud.
If you don't care about about the noise level, they are all good mufflers. However, if you do care about being
quite, then OEM gets the job done.
What brand muffler did you have on it most recently?
g
Thanks,
That is the consensus I am getting; the OEM is the quietest, longest lasting,
negatives appear to be it's size and it's cost, and it's whistle.
Now wondering if the OEM muffler and/or resonator have been reengineered
or improved (internally) to get rid of the whistle??
Anyone out there know if it has been redesigned since the factory installed mufflers went out the door?
G
I just finished this project about 2 weeks ago. I was under the truck looking how to put on the lift when i noticed the muffler was cracking at the edges, it was also evidently collapsed inside.
My first reaction was to put an aftermarket high flow on there so i searched out a flow master 0 series recommended on here. After removing stock muff section and tryng to cut and fit new one using existing piping, i said f it. The angles of the existing are to hard to work without a lift. We were taking it off and on between weldings.
Went to autopartswherehouse and bought a bosal replacement for like $125 shipped, bolt in using existing everything...kicking my dumbass for trying to gain what, 2-3 hp?
oh, and its quiet like stock and i have no power loss in the 2-3k rpm band like before. My old muff was killing performance.
coolbreeze;
Can you put that in writing, again; the Bosal is as quiet as the OEM?
And the $125 was for the muffler/pipe, or for both the muffler/pipe and resonator/tailpipe?
Direct exact bolt-on, no banging, tugging, pulling, swearing?
And, the problem at 2-3K; are you saying that you had previously lost torque in 2-3K due to
an OEM muffler that went bad, or that the Bosal was an improvement over a stock, good condition, muffler??
G
