OEM Locker Dial Dimensions
Will Van
GOLD Star
Austin, TX
Does anyone know the dimensions of the OEM locker dial? Dimensions in mm preferred.
It appears to be square (same length x width).
Outside to Outside as you have depicted....mine measures about 44mm each direction. But its difficult to get an exact measurement as the switch is recessed a bit. Of course that doesn't represent the 'opening' in the dash....just the outer dimensions.
Outside to Outside as you have depicted....mine measures about 1"-3/8 or tad under 35mm each direction. But its difficult to get an exact measurement as the switch is recessed a bit. Of course that doesn't represent the 'opening' in the dash....just the outer dimensions.
Thank you!
Can anyone double-check these measurements for me? 35mm x 35mm seems small for the dimension .
