Oem belt design
Rigby, Idaho
I lost my belts on the highway over the weekend. Had the cruiser towed to the local Toyota dealer to repair since it was much closer. The belts they used are ribbed or have cogs/lugs underneath. It seems that last time I bought belts they were smooth. Anyone know for sure? The belts are now making a whine that they say is the alt idler but I suspect it may be the belts as I have heard that complaint about non-oem belts in the past. Hoping that @beno or @cruiserdan Or some other expert can confirm.
The whine is from the new belts. The originals were smooth. They must have just used whatever they had in stock. They don't always use OE parts for repairs.
Nothing is being hurt, but if you want new belts, better to order them from a vendor on Mud and know they are correct.
I put Gates on mine and seems to be fine. They are smooth not cogged.
Rock Auto Carries them.
The ribbed drive side was pioneered by Goodyear and intended to decrease propensity for multi groove belts to whine or squeal when ever so slightly misaligned.......if there is a whine you need to define it and locate its source, the coved looking multi ribbed belts do not make any noise on a properly operating system.
Something is wrong, so better to find it soon rather than along a trail or highway.
Btw, did the shop address this sound with you when you picked up the rig?
Ribbed belts have several advantages, run cooler, more flexible, etc, but the 1FZ has a flat idler pulley that will make a whine if the ribs are on the inside. Doesn't cause any damage, just noisy.
Just a follow up to confirm that the noise was from the belts. Now running quietly as before. Yes @Lionsgarage, they did identify a problem with the idler pulley on the alt and wanted to charge me another $160.00 to replace that. Funny that the issue went away when the correct part was used.
