Odor smell
Hi Guys
I tried every trick in the book to get the odor smell from my 2005 lx470
I think the smell coming form the leather seats I hate to spend $1000 on new seats cover to find out it's not the reason
Any more tricks Or suggestions
Thanks
Have a nice weekend
Clean out your HVAC system?
If you have rotting tissue or vegetation if your HVAC, no amount of spray thru chemical will work. You need to find the source, remove it, and bleach the area.
Both cabin filters replaced?
A few years ago while driving I heard a thunk, followed by loud vibration of the blower fan. Lowering the blower fan was simple. When I did I found one adult and two baby mice. The adult was freshly dead and the babies were barely alive, all on the vanes of the fan.
I can only imagine what that would have smelled like if they hadn’t been gracious enough to audibly announce their presence and location.
The fact that your smell diminishes with recirc suggests to me the source may be upstream, but taking a look at the fan is reasonable.
The cleaning of the HVAC system mentioned about sounds like a great place to start. Thinking of doing mine.
Previous owner of my GX470 had a major food and latte coffee habit. Result was spills all over the seats and carpet down into the console and shifter area. The milk with sugar content of the coffee was the problem. The car really stunk.
I ended up pulling all the seats, rear lower interior panels and removed the carpet. Found enough food to feed a family of 8 for weeks. Found some money too. Draped the carpet over a couple saw horses and employed the power washer using the HOT water connection of the utility sink. Got my ryobi drill out with the rotary drill brush kit off amazon with a witches brew in a pump sprayer of dawn detergent, tsp, oxiclean etc. Brushed, soaped, brushed, rinsed and rinsed again. A surprising amount of sand came out.
Dried is the sun for a day.
Looks great and no smell at all.
I used a rag with baking soda to clean the seats. Replaced the destroyed bottoms with cover kits from richmond upholstery. Perfect color match.
Looks and smells beautiful.
Good luck
Both? Just the one under the passenger side where is the 2nd one?
Yes. There are two air filters behind the glove compartment in the LX.
Also use a shop vac when filters are removed since a ton of stuff might be down in the chamber.
