Odd ignition issue
New York
I've had an intermittent issue where if I drive for 15 minutes or so, about 5% of the time the car doesn't start when I turn the key to start it again. It seemed that taking the key out and putting it back in resolved it, so I didn't think much of it. Now, I'm trying to start the truck and consistently seeing the issue after sitting for three weeks (in single-digit temperatures). The battery appears to be fully charged and the immobilizer light on the dashboard behaves as expected (flashing until key is inserted). When I turn key though, no ignition at all (no relay click or starter motor sound). All of the other systems appear to get power and function just fine.
I disconnected the battery (positive terminal) and reconnected, and the truck started fine. I let it run for five minutes and tested, but no ignition after shutting off. Any ideas what's going on?
I'm going to try cleaning and checking the grounds from the battery tomorrow.
Thanks!
Have you tried starting in neutral when this happens? I had a similar issue and that always worked.
If you turn the key to ignition and jiggle it around a bit, does it start? Could also try starting directly via battery to starter jump. Might be worth pulling ignition switch and inspecting the contacts, as it sounds like it’s going from intermittent to persistent. Might be a symptom of moisture in there or something.
As above, inspect the park/neutral safety switch. Also, make sure your grounds are tidy and solid.
Those are probably the lowest hanging fruits before hunting for shorts/busted harness wires etc
Thanks! This does work. How did you resolve the issue, replacing the park safety switch?
Truth be told, I have no clue what the issue was. I had the intermittent problem on and off for a few weeks, did some reading, bought a starter relay, and it just stopped without intervention. I still have no clue what was the issue or why it stopped. Sorry I can’t be of any help there.
I hate to be captain contacts here, but check the harness connection for the switch, as well as wiring, before you throw a new switch at it. Not impossible for crud/moisture to get in there, and would contribute to the intermittent nature of the issue. The waterproof seal in there could be compromised. Just ran into exactly that on one of my projects. Waterproof “gasket” inside the connector appeared to have been bound up in there allowed some moisture into the connections. Dried, cleaned, polished pins and been good since. May still need a new switch in future, but saves me time and money for now.
