I purchased a front axle set of bearings yesterday, steering knuckle, inner & outer wheel bearings. When fitted the inner outer race is not tight in the bore, it can rotated by hand and lifted up and down about 1mm. It had to be tapped all the way in but just seemed to be loose once seated
I removed the new outer race and noticed a ridge which seems to correspond with the depth of the bearing + 1mm
What should I do, just ignore it and put it back together or, will the outer race end up spinning in the hub
