Occasional backfiring help
Lawrence KS
Hey Gang..
I have a rather intermittent issue that I'd like to fix.. Occasionally my 93 will backfire when starting it up. It may happen like once a month or so.. I hear a popping from the engine compartment and then I stop cranking in over. Wait a few seconds and it will crank for a long time then turn over and start up and run just fine. I have set my timing to 5 deg BTDC which is a bit over the stock setting but within the normal timing settings as far as I know. What would be some things to check? I am thinking plug wires? I have new plugs and wires, but the wires were an el cheap-o set I got off amazon. At the time I could not afford the OEM ones at over 100 bucks. This truck sat in a field for a few years and the wires had been chewed through by animals.. The cap and rotor all appear to be in good shape, but maybe there is a hairline crack in the cap? I also checked the CATs to look for clogs and they were clean as a whistle.. Replaced the O2 sensors when I inspected the cats as well. Is there anything else that could be causing the backfire I should look into?
It was the worst it has ever been today. It was raining out and I stopped to get gas (BTW 9mpg in the city ughh) when I started it up got the backfire.. I then made a trip to the store to get some things and came back out 5 min later and started it up backfire again.. Never had it do it two times in a row like that. I wonder if the moisture in the air had something t do with it? Well thanks for any thoughts on what else to look into..
Another thread here recently had a similar issue and he fixed it by adding a ground to the ignitor on the fender. It grounds through the bracket.
Interesting.. I must have missed that post. Not coming up with much searching for it. Any chance you might have a link? Thanks Mark
What are the possibilities of a backfire thru intake(solved)
That us the title of the recent thread. I dont know how to 'do' links
Oh you have to be kidding me.
He didn't add a ground. His HT wire from the coil to distributor was scashaad. He needs a new set of wires.
Sorry, I glazed over it and the repetitive "advertising" must have made me think that!
Either way, read the thread that had the problem and follow what happened there......
LOL!!!!!
LOL!!!!!
I couldn't stop laughing. That was pretty good.
Cold start injector dumping fuel (or leaking) when it shouldn't??? Someone more experienced than I should comment on the likelihood.
It doesn't have a cold start injector.
