o2 sensor question.
Middle Tennessee
did some searching, but didnt find any tips on what i was looking for. it seems that the PO had put new o2 sensrs on the LC ( bosch ) which in my opinion are garbage! i just replaced the cap rotor , wires, and plugs and it seems to ocassionally at a stop to idle a bit rough 5-800 rpm but it doesnt die, and it evens itself out after 20-30 seconds. think it has to do with the crappy bosch sensors?
Could be.
Mine had the exact same issue. The second i switched to OEM 02 sensors the truck ran 100x better.
What type and how old are those bosch sensors ? The data sheet says they are good for 160K. Could it be a "mis-print" ?:confused:
I just put them in because they were new and free. I'll replace them with OEM when they go. What is the deal with the O2 sensors ? I never understood Do they clog, get contaminated or wear out ?
Can someone explain ?
IIRC, something to do with the wiring of aftermarket 02 sensors make them not work properly. I think adding a resistor or something helps? I remember reading a lot of threads on this when i was trying to diagnose my problem. The end result of my research was, ditch the aftermarket 02s and use OEM.
Did that, rough idle was fixed instantly.
Thanks for the explanation... It makes sense, I think I read the bosch uses almost 2x the heater current over the Denso's. I bet it has something to do with the temperature range. It would be easy to figure out if we had a Denso datasheet
I have a bosch o2 sensor cat, can't find one for Denso
Bosch OS Sensor catalog and datasheets
They arnt very old. Maybe a year at most.
Whats this about putting a resister in?
Search :)
I tried making mine work and vaguely remember reading something about this. I am not 100% sure though and have no idea where i remember reading it on here (as in which thread).
What i did find and remember the best about my searching on this topic was that i was much better off to just replace them with new OEM sensors.
Does anyone have a Denso O2 data sheet ? If I could find one, I'm sure I can come up with something that works
on a (semi)related topic- I had code 26 pop up after a water crossing last weekend, (rich mixture) -popular opinion from here pointed to the O2 sensors or the wiring being the cause- low irregular idle, odd feeling behavior.
yesterday after about 100 miles of standard and offroad use the CEL went out and the idle, feel came back to normal- factory O2 plugs seemed to fix themselves? Another reason to use OEM....:rolleyes:
That rough idle was jus the DTs as they were "drying out".
It happens to the best of us time to time.
