I purchased a 93 LC about a month ago. It ran rough on startup, but smoothed out after it had been driven. Ran great once warm. I would run fairly smooth, but with a hard miss. It was random, but frequent while cold. Now, it has started doing it even when warm.
Maintenance had been fairly neglected.
Appeared to be just enough to keep it going. CEL didn't light up on startup, so I figured it was either out or unhooked. Checked today and it was missing. Replaced light, pulled code, and it said O2 sensor. Would this cause the miss?
This was the only code showing. I know the plug wires are the original 93s and figure the plugs are too. It has about 190,000 miles. Only other things I know for sure are that I get a small gas smell near the driver floorboard and hissing gas cap. I don't know if the charcoal canister can cause any engine issues or if it is just an environmental issue.
Lastly, what are the common causes of the O2 sensor code?
Thanks
Thanks
