O 2 Sensor options
colorado front range north Lat: 40:23:57N (40.399
Website
www.rm-mi.net
my check engine light says i need to replace, the NAPA has them at 150 $ a pop and i need 2.
any other options? on my 80 i have two cats and in front of each cat is the O2 sensor...
options? i did not see any with a quick search here.
thanks
justin in colorado
The general recommendation is to use the OEM ones. Many folks have had trouble with recurring codes after installing aftermarket ones. However, I have heard of some--and know at least one person--who has had the same problem with the OEM ones as well. It's a crapshoot if you ask me.
I installed some "universal" Bosch ones that use a different sort of sensor that apparently causes havoc with OBDII vehicles. My OBDI 1993 likes 'em just fine. I've had them in for over a year and never thrown a code, and my truck runs great. Your results may vary.
dhup! good idea.. will do that for sure!
thanks thank tank tan an a thanks man :beer:
Have your vin # checked at a dealer there was a recall on 94 o2 sensor's
Call Cdan he will have the "correct" pair for your 94 w/nuts at your door ...............CEL gone.
