Not getting any fire from DISTRIBUTOR
South East Texas
ok I rebuilt the motor in a 92 3fe that got flooded out, did a complete rebuild from crank to head. Today i got every thing back together i went a head and got the wiring harness and changed it new ECM, dist., ignition switch, starter, altinator all the good stuff. I got all the wires hooked up to turn it over, after turning over i am getting no fire out of the dist, i am getting fire from the coil, i am still in the middle of getting every thing back to gether just wanting to here it run but it wont. Can any one help, The insterment cluster is out could that be my problem i am waiting on one to come in to replace it. Well thanks
#1. When you post stuff in the middle of the night have a little patience until you get a response. Some of us sleep at night.
If you have spark at the coil and not at the dissy then the problem has to be a bad wire from the coil to the dissy; a bad rotor or a bad cap.
