Anyone have luck in identifying their noise? This seems like the closest description to one I've been chasing for many years. Pulled the exhaust fan in dash out yonks ago as couldn't see it doing anything useful since it just vents straight into the bulkhead (and needed extra space for cabling of extra switches and dual din head unit etc.)
Mine only started many 000 km after changing speedo cable, but always figured that was it. Have cleaned and re-lubed my cable about 4 times in the last week, re-fitted it every which way (there's only so many ways it can fit ultimately), and have then started isolation testing to see if I'm just crazy.
With the speedo cable disconnected at transfer case I still get a buzzing albeit quieter and less frequent which makes me think there may be 2 buzzing components. Only occurs while under acceleration, never at cruising speed. I'm still testing with having only some of the electrical plugs in the back of cluster connected, but I did disconnect the one that drives tacho and STILL got the noise... which means that only the pressure gauge or temp gauge could be causing it - They don't appear to have moving parts to me, so not sure how this would make sense.
Going to do about my 12th pull-apart, clean, re-assembly of the odo and speedo wheels, but they're obviously not the only issue.
Weird that it all started happening at the same time for absolutely no reason one day when cruising on highway.
Ready to break glass over this issue as I was sure the speedo cable had to be it, but nope! Shopping for entire replacement cluster as well
