For Sale NOS JDM parts clearout
Greendale B.C Canada
Time to clean house, or garage as it were. All parts are new genuine Toyota, prices are in USD, do not include postage unless noted, located in Canada, but can ship from WA 98295.
HZJ78 /79 Fan Shroud 16711-17140 $ 75 plus postage. SOLD
LJ7# 90-93 shift cover set (Boots), Trans/T case, Grey. 58808-60042-BO 58805-60012-BO $60 SOLD
HZ7# Clutch Disc 275 mm 31250-60223 $100 SOLD
HDJ78/79 Hose, Air cleaner #1 17881-17111 $30 SOLD
HDJ100 Relay, air intake Heater (glow) 28610-17090 $100 shipped
BJ7# (plus a ton of other models) Joint/Union, Heater hose 87251-30200 $15 shipped
BJ74 13B-T Thermostat Gaskets x15 (Split O-Ring) 16341-56030 $10 ea shipped
1870957
I’ll take the fan shroud and clutch disc. I will PM you.
Misc NEW HDJ81 parts, prices include postage in lower 48
Hose, Air Cleaner #2 17882-17010 $80
Hose, Oil Cooler (Trans cooler) x2. 32942-60091 $40 ea
Hose, Water (Block to heater valve) 87245-60320 $40
Hose, Air intake (Turbo to crossover pipe) 17341-17012 $25 SOLD
Hose, Oil dump, turbo to pan 90910-05206 $15 SOLD
Pipe, Ventilation (valve cover to air box) $50
Hose, ventilation for above 12261-17010 $15
Spring, timing belt tensioner 90507-27003 $20 SOLD
Insulator, Turbo (heat shield) 17272-17010 $20 SOLD
Fillers, Front door glass x 2 (holds glass to regulator bracket) 69971-90D00 $20
Relay assy, Glow 28610-17060 $110
Bar, Fan Belt adj. ( needed to upgrade to big body 100amp alternator) $20 SOLD
Clamps, Injector pipe 4x No1 type with nuts 2x No2 type, no nuts $30 SOLD
1870972
1871045
If no one else has claimed it, I would also like the crossover pipe to turbo hose, the turbo dump hose to pan, and the turbo insulator shield.
Done deal!
For anyone chasing the discontinued Toyota 17882-58080 air intake hose, I’m working with a rubber manufacturer on a proper aftermarket replacement (EPDM, molded, correct side port, OEM-style).
If all goes well, there should be new hoses available in a few months. Just wanted to let folks know something is in the works.
I’ll update once production is confirmed.
