- Joined
- May 18, 2019
- Threads
- 14
- Messages
- 79
- Location
- Sandpoint Idaho
- Website
- www.thelandcruisershop.com
- Year
- 1977
- Vehicle Model
- 40 Series
- Location
- United States
- Mileage
- 20000
- Color
- rgb(0, 128, 255)
Located in Sandpoint ID at The Landcruiser Shop
PRICE: $23,500
HELPING A CUSTOMER SELL THIS VEHICLE, THIS IS NOT A SHOP BUILT TRUCK NOR DOES IT REFLECT OUR QUALITY OF WORK.
Clean titled 1977 chassis with an Aqualu built all aluminum tub, fenders, tailgate body. Windshield/hood/grill are Toyota
Vehicle currently runs and drives and goes through the gears but would require attention in areas to become a daily driver.
A great platform to build off of into a desert runner or a truck that has the classic feel of a 40 without the price tag or worry of rust!
Exterior:
Truck's value is a sum of its parts and could be a really cool project for someone to put in the effort and have quite the offroader. Couldn't replicate build specs for anywhere near this list price. PM or email and we will do our best to answer your questions.
Cheers !
PRICE: $23,500
Exterior:
- Aluminum body painted in Voodoo blue color w/ rhino lined hood windshield frame
- included are paint matched aluminum 1/2 doors
- Best Top soft top w/ STC splittable soft doors
- Front winch mount bumper w/ Warn 8274 winch
- Rear tire carrier w/ matching 5th wheel & hi-lift jack
- O.R.S rocker guard side steps
- BFG 33x01.5x15 Tires with Black steel wheels
- Small block chevy V8 w/ throttle body injection, AC, PS
- Aluminum radiator, edelbrock intake manifold,Erson valve covers,tube headers,
- 700R4 trans adapted to original 40 transfer case
- original axles front and rear
- large aluminum long-range gas tank
- Full 6 point roll cage
- Auto-Meter gauges including RPM/speedo/fuel/volts/oil/temp. Gt grant steering wheel
- Corbeau heated front seats w/ lumbar bladders. Fold down back seat
- Onboard Viarr air system with 2.5 gallon tank and pump, gauge
- modern HVAC unit
- Notable front end wobble when applying brakes, steering wheel feedback at speeds
- Notable drivetrain noise when letting off the throttle and coasting
- 4wd will work but takes effort to engage and disengage due to small lever hole/ linkage
- Exhaust is intact and not major leaks but not an ideal setup for fit and finish
- Rear large gas tank had previous clearance issues with R shocks.
- front birfield joints show age-related wear and tear
Cheers !
