Normal Turning Radius?
If you are only getting 3 turns total going stop to stop, you probably have a quick ratio box. That's great for a sports car, not a truck. 4 turns is my starting point.
@Augusts96 - Not sure what power steering setup you're running - The original poster was running a saginaw setup. Those saginaw steering boxes, as Shawn mentioned above, came in at least two versions - a 4 turn box, which is what most of us run, and a 3 turn box (actually 3.25), which is the quick-ratio box. My truck originally had a 3.25 turn box - it was definitely a little squirrelly changing lanes but I think it gets a worse reputation here than it deserves. Your brain calibrates to whatever box you're running - you get used to it. That said, I moved to a 4-turn saginaw box when I rebuilt the setup.
If you're not running a saginaw setup, then we will need a shot of the steering box to help you further. There are a ton of different conversion options.
Well here's my current box - any ideas? :)
Looks like mini truck or stock power steering to me...but I don't really know enough about those setups to say for sure. Not sure how many turns those boxes have normally.
