Normal Oil Consumption for 1FZFE?
Los Angeles, CA
Guys,
I noticed that my rig consumes about a 1quart of oil every 1k miles. But, there is no blue smoke, no valve rattles or oil leaks. Its currently runing with Valvoline 10W-30 oil. I understand that the 1FZ is overworked with the weight penalty, 4wd driveline stress & all. So I can defenately see how the engine would consume a bit of oil, I just want to know if this is the norm? While I was searching, I saw some folks that consume about a 1qt every 3-4k miles / even 5k after the PCV valve changed.
P.S. where is the PCV Valve located?
I burn half a qt every 4k miles so it seems like a lot to me. I "think" 1qt per 3k miles was supposed to be normal.
the PCV is located at the front of the valve cover. It has a hose that goes from it to the intake plenum.
I have a '93 FJ80 and I run about a quart per 1k miles but have a minor oil leak that I need to fix...I bet that extra weight will weich it down, but maybe you need to change pcv valve. Also check for sludge buildup in your valves by taking off the valve cover! its pretty nasty stuff but if you haven't been running on low oil then it should not be to bad. Clean that by hand with a metal brush or a toothbrush and just put it in a plastic bad and dump it. you could also replace your valve cover gasket (VCG) to be safe...and your toyota dealership will charge you a coupla bucks, at most $25.
Also do you get frequent oil changes? If not then maybe now is the time to go get one, get new oil, and replace filter perhaps..
Oil consumption is dependent on many variables. Having said that, my vehicle consumes 0.5 - 1.0 qt. of oil every 3000 miles when using Mobil 1. After a few oil change cycles on Mobil 1, I've switched back to Rotella 5w-40 and and as result have no noticeable oil consumption.
IMO the most important question hasn't been asked- How many miles are on your rig? If you have 300k+ miles, then you bound to burn oil at a greater rate than a 100k Cruiser.
I burn no noticable amount of oil between 3k oil changes. My Cruiser has 114k miles.
TK
with 120k miles on wifes 80 .. there is no oil comsumpotion at all .. I'm using Castrol 20W-50 ( I'm in Panamá ) but if where me would thing shuld be rings related .. ?
93 with 280,000 +mi.no oil consumption use dino oil 10/30:steer:
At 134,000 miles 1996 LX uses less than a quart of 10w30 between 3000 mile oil changes. I have never added any oil between changes.
According to what C-Dan has told us in the past, Toyota considers consumption of 1qt per 1,000 miles as within what they consider to be acceptable consumption.
M1 goes through my engine (175k) much faster than the Rotella does so I will probably stay with the Rotella from now on.
-B-
TK
It has 130k / daily driven 90 miles / 90% Freeway / No off road
-B-
Thanks, this gives me some peace of mind
My 250K+ 3FE goes through oil at about 1qt/1000 miles. Hopefully less with the Valvoline 20W-50 I just switched to.
I know a guy who's 1ZZFE-equipped Geo Prizm burns 2-1/2 qts every 500 miles :eek:
-B-
X2
I get very little consumption with 5W-40 Rotella vs. quite a bit with M1. The Rotella is worth a try, many have reported lowered consumption.
Consumption varies greatly on 80s, depending on the individual vehicle and how it is driven. In town easy driving, I will burn a quart every 3000 or so miles, it drops to 1000 miles when running it hard on trips with full throttle climbing and 80+ mph highway speeds.
If you have high consumption you can do a few things to help lessen it:
1) Make sure your PVC valve has been replaced.
2) Use a 40 weight oil. Mobil 1 0w-40 is a great oil, but suffers from high consumption in some rigs. I used to recommend Shell Rotella 5w-40 as the oil value leader because it was a Group III synthetic at a great price. Now that it is $22 per gallon, I would suggest just ponying up another $4 and buying Mobil 1 5w-40 Diesel Truck and SUV. You are going to say a "Diesel" oil??!!!. The answer is yes, a fleet oil, the same as the Rotella 5w-40. Alternatively as a lower cost oil, take a look at Mobil 1 10w-40 High Mileage, which gets you 5 quarts for $25 or so.
Quit wasting your money, if you are running mineral oil, move your changes out to 5000-6000 miles. We have plenty of UOA's here showing Mineral is good for that mileage without a problem.
Chevron Supreme is about $25 for a case of 12
I have a case of Delo but forgot the price
They are both labeled ISO SYN, which I guess means very high quality base stocks.
these go easily 5K miles
I don't have noticable oil consumption between intervals
