Non USA Cyl Head
Sedro Woolley, Wa.
Just bought a 78 40 with a later model enging#514149 sounds like about 1984. It has I beleve a non USA head with no air rail holes.
nyon know anything about this.
I have one.. not on the engine though.
what do you need to know? They are identical save the air rail ports because non usa trucks didn't have emissions requirements.
Nope; valves are the same. Toyota was not that imaginative.;p
Interestingly enough, some of the firetruck engines I imported years ago were not drilled for the air pump but WERE outfitted for EGR! JDM spec.
61010 is the early 2F head. 1975-1976. Open chamber, low compression.
If it is really on a 1984 block, check to see that it has domed pistons to go w/ that head. I've seen several engines that had cracked the original 81-newer head and were replaced w/ early heads. That gives a 6.5:1 CR, about 115-120# compression. It will run, but low power and bad MPG.
