Anybody use a fuel tank out of some other vehicle to add a second tank?
I sure do wish I could see all the parts to this mod. I can't believe it would be that hard to do . . . .
I like the idea of a fixed gas can.
You can't just hook up a fuel pump to move the gas from the "can" to the tank?
There are only a dozen or so write-ups on this - a little search would go a long ways. Terms such as aux auxillary gas tank long ranger 24 gallon 48 gallon secondary dual filler neck will all help you on your way...
I have considered using a tank from another rig. There's a great write up on this at expeditionswest using an isuzu trooper tank under a tacoma double cab.
Expeditions West: Toyota Tacoma Auxiliary Fuel Tank System
I have looked at Jeep Liberty tanks, I think they would work as would a lot of others. I was considering putting a Jeep CJ filler door in the body behind the wheel well as opposed to an expensive OEM dual filler neck. You can then either use the tank mounted fuel pump to pump into the main tank, or figure out how to valve and switch the lines so that the engine runs off the secondary tank. I need to investigate fuel pump pressure compatibilty before i decide which way to go with that.
I think this could be done for under $300.00 with a little booty fab work.
Has anyone ever had issues since most if not all of the aftermarket tanks are not DOT approved? I know they approved for offroad use but I sure would like to use mine more frequently then that.
