22RE, 1990 Pickup
Brief history:
1.) Noisy power steering pump. Bleeding the system did not help.
2.) Interestingly, if I drained the fluid, replaced the fluid and bled it, the noise would go away for a while.
2.) I replaced the pump with a rebuilt unit a couple of months ago, filled reservoir with the fluid and bled the system. No noise for a while, but now the noise is back.
I did the 'screwdriver' test. The noise is not coming from the p/s pump front bearing or the pully bearing. If I try to bleed the system, I get no bubbles.
Any ideas on what is causing the noise? It is most noticeable at slow idle. The load doesn't affect the noise, like is typical with faulty pumps.
Thanks for your help.
Brief history:
I have had very good results running it in many Toyotas.
