I have a HDJ80 with a clutch that started to make a creaking sound around Christmas time. The sound is only there the first half minute after a cold start, and only when the clutch is not depressed. As soon as I press the clutch the sound disappears. The engine need to run at some speed.
From what I found on the net this is probably a worn clutch trust bearing. When clutch is not depressed, the bearing is driven around by the clutch because of a slight friction between clutch and bearing. When pushing the clutch in, the bearing is loaded and seats better and sound disappears.
- Is this normal? There seems to be no way of adjusting the fork so you can remove the bearing completely away from the clutch, as it is no my BJ40.
- Why isn't the sound there all the time, not only half a minute? Heating?
- The clutch and bearing has only run 75.000 km since it was changed. Isn't this a bit early to be worn?
- Should I care about changing the bearing no, or can I run e.g. 10.000 km more?
- Or can it be something completely different?
