Noise when turning.
If went with a slee non-heavy duty(I don't offroad), any recommendations on slee? I did check on price and they're about $500+ per side.
Are there any good quality brandname companies that make birfs for the 91-92's so that I wont have to use drive plates?
... so that I wont have to use drive plates?
Your truck has drive plates. The only issue is if the size of the drive plate matches the birfield. The short birfields require a short (91-94) drive plate. The tall birfields require a tall (95-97) drive plate. The drive plates are about $40 each side.
-B-
Are you sure those aren't OEM, that's close to the smart shopper (cruiserdan) price? The longer splines are an upgrade to fix a weakness, the shorter ones wore out relatively quickly, so all replacements that I have seen are the long type, even tho some of the parts descriptions have it backwards.
If I were to spend $500 ea, would get OEM, for generics I would get the cheap ones and take the chance.
eBay Motors: TOYOTA LANDCRUISER BIRFIELD FJ80 FZJ80 #8709 (item 7995742247 end time Dec-06-08 18:55:24 PST)
eBay Motors: 2 OUTER CV JOINT TOYOTA LANDCRUISER 91-94-98-00-02-04 (item 160287280544 end time Nov-25-08 05:57:52 PST)
Wow! $80 vs. $500 I'd almost want to get one just to test. Mine are original and have way over 200k miles on them. If these got 40k on them it may amost be worth it. Put them in, do one repack, then replace. Of course if the metal is so bad they actually fail versus weraing that's no so good.
Is anyone running non Toyota in their truck right now? how are they holding up?
Also, if upgrading to newer style Birf on a 92 all I need are the replacement drive plates? Everything else is cool?
One of the guys in our club (lshobie on mud) got a pair of non-OEM birfs for less than $100CAD per side for his 70 series a few years ago. He wheels pretty hard and I haven't heard of them breaking yet. :meh:
Correct, if you don't replace the plates, the spacing is off, the birf has too much play and knocks the dust cap off, etc. Most of the time the early plates are very worn anyway.
I thought about using an '80 axle in a buggy, wanted to run locking hubs, the short birfs are the correct length for them, but couldn't find new short style. Locking hubs would be an option for an early rig that doesn't get wheeled? Get a set of FJ60 or straight axle mini hubs, run hubs unlocked, CDL locked, if 4x4 were needed, snow, etc, simply lock the hubs. This would greatly increase clicking birf life, especially if they were swapped side to side.
anyone know who actually supplies the birf assembly to Toyota?
Wow! $80 vs. $500
Actually, that last eBay listing is $80 vs $1000 since it is a pair of birfs. Free shipping too. That has to be worth $25 for a pair of birfields. Not sure what those rubber boots are for though. Makes me wonder if the pics are correct because they are calling for those same parts to fit the IFS Land Cruiser 100-Series and those are not anywhere the same as ours.
-B-
-B-
This may be a little off topic, but what year landcruisers are solid axles vs. IFS?
Sorry for the error. I meant the oem ones were about $500 a piece. The aftermarket slee's were about $250 a piece or something in that neighborhood.
my 93 got clicking noise before this happen,ps side
Did yours click as well when you were going straight? By all means, my didn't click all the time. Just whenever I make hard turns. It's been this way for the past year. *kinda like a bad cv axle on smaller cars*
Speaking US models only... Up to and including 1997, all Land Cruisers have solid front and rear axles. The 1998 and up models have all been solid rear and independent front suspension.
-B-
-B-
The reason I asked is because my brother drives a lifted Suburban, I drive a Landcruiser. His is solid, I told him my was solid also, he didn't believe me because he said solids shouldn't have coil springs in the front. I told him the coil springs didn't matter.
Pretty much the same deal. Birfs only deal with turning angle, the ball grooves in the star and bell are straight. CVs deal with turning and suspension travel angles and have angled grooves.
So than I should be safe/ok to drive until summer again.?? I don't wheel/offroad at all. I need to save $$$ for the new birfs. I'm going to go with oem.
Maybe, but it really depends on the wear and we haven't seen any pics. Avoid hard turns at full lock, particularly in reverse. The main thing was to get proper lubrication in there and you have done that.
-B-
X2 on what Beowulf said, the big thing is being easy on the throttle when turned. One test that I use; is the click a noise or can you also feel it in the steering wheel? If it's just a noise they will probably go a while, if you feel it, they are closer to done. One local ran a set of clickers for a couple of years, even did some mild wheeling on them. No guarantees as with any worn part, it's a gamble.
What would cause a louder clunk in reverse while tuning but no clicking moving forward?
As much as I don't like to gamble, I'm going to drive it as is for now. I really don't drive her much. I have other dd's, so she sits in the garage. I really don't feel like working on her now especially with winter coming. I may take her ice fishing and all, but I will take her easy and avoid making hard turns.
