Hey mud,
I recently had my rear pinion seal replaced and a new companion flange installed at Land Cruiser Heaven.
About 100 miles later I started hearing a whirring noise from the rear while driving:
- noise increases with speed and does not adjust to transmission gears
- when shifting to neutral while at highway speed, the sound stays the same
Things I've inspected
- jacked up rear end and put t case in neutral.
- removed rotors and calipers from equation, put wheels back on and spun and no noticeable noise
- no play in wheel that would indicate rear wheel bearings
- driveshaft is solid going into rear diff. No side to side or in and out.
- using a stethoscope and turning driveshaft by hand I do hear som grinding they seems to be loudest at the rear diff but I can hear it faint from other spots along the axle as well.
Any ideas?
Any ideas?
