Since I'd venture to say that 99% of you all tend to know more about these trucks than I...
Driving down the road the other day doing 60 mph and the engine dies. Pull off to the side with little fanfare. Try to start things back up and it turns but nothing starts rumbling to life. Tow it to my place.
Fuel or spark right? Fuel looks fine; you can see fuel in the filter, the pump is new, and the carb sight glass is half full (or half empty as I was pissed it wasn't starting).
Spark... Nothing on the plug 1. Nothing on the center wire to the dizzy. Thinking ignition coil?
Per 2F FSM (8-6), I checked the voltage and I get approx 12V for each of the tests. Ohm meter gets nothing between the + and - posts nor does it get anything between + and high tension posts.
Am I on to something here? New ignition coil time?
If that is the case, will any suitable (read NAPA or Autozone) do or should be ordering some hard to find part from some place that won't get to my door today?
