This is driving me crazy! 1973 FJ40 with an F engine. Despite 4 days of trying, I can get no spark.
I tested the points and they open and close as they are suppossed to - checked it with an Ohm meter. Checked the gap and that is fine too.
Tested the coil it doesn't seem to work. Bought a new coil. Installed it. Still no spark. The distributor is grounded and I ran a wire directly from the battery to the + side of the coil to make sure it was getting power. Still no spark.
I bench tested the old coil by attaching the + to the + on the battery, held the center electrode about 1/16 inch from the negative terminal and then attached a wire from the - on the coil and I would tap it against the - on the battery. Theoretically, when I release the - wire from the battery, the coil should jump spark. But no spark. Perform the same test on the new coil. Still no spark. Perform the same test on the coil taken from my neighbors old Bronco - still no spark.
What am I doing wrong? I HATE electrical problems!
