no spark
ive gotta 91 80 with around 225k on it, it has always been turnkey
went to start it up after work and i got nothing
im notgetting spark, im getting power all the way up to the coil, my grounds are good, and ive replaced the coil twice thinking that the first may have been faulty the 3 return wires off of the distributor to the ecm have continuity but im not getting anything at the ecm off of these wires either in start or run the distributor,rotor and wires are all good im more of a shade tree mechanic so any advice would be great
Check your ignition relay located in the engine compartment by the PS front fender, it is a rectangular piece of aluminum with pins. That one go bad also. Your symptoms is just like my brother in law's Cruiser.
if the ecu is powering the ignitor and coil, should i be getting power from the distrbutor to the ecu in run or start, i would think that i should unless a relay is keeping the ecu to make the connection
