No spark!!!!!
Daly City, Ca
I replaced by cyclinder head and connected everything back together and now the engine has no spark. Could anyone give me any advice ..
Does it crank but no fire? Does it just click? Have you checked your fusible links for continuity?
With the key to run and no CEL, the bulb maybe burned out, or more likely the ECU is not getting power. No power to the ECU = not gona run.
I’ve checked the the power going to the ECU getting 12v. I am replacing the ECU. I’ll let you know how it goes. Thanks everyone.
1937867
Would like to confirm if Is this the fuseible link that need to be replaced. I’ve ordered the part form the dealer since my local Automative shops don’t carry yet.
Yes, that is the fusible link. You can remove them from the connector and the black box and test continuity. Without all three, the truck won't run. I had a very similar issue, cranks but no fire. I had a short on injector #5 that kept blowing the fusible link with the gray connector.
Before you install a new fusible link, look for any exposed wires or burned jackets. Otherwise the fusible link will just pop again and you've just thrown away $15.
Thanks for confirming. I hope this solves the problem.
Did you test them first?
From an older post:
A real basic test of the 3 fusible links:
FL1/AM1 (small ring terminal): if the dome lights work it's good.
FL2/AM2 (grey connector): if the CHARGE lamp lights when you turn the key to ON, then it's good.
FL3/FL MAIN (large ring terminal): if the brake lamps work when you step on the brake pedal, then it's good.
This forum kicks ass!! Thank you again everyone for all the help. My rig started for the very first time since I replaced the cyclinder head. Cheers!
My next problem is my MAF. When I plug it in my engine turns off. Is my sensor bad?? It was left unplugged when I started the engine for the first time I didn’t notice to plug it after 5 mins. Than when I plugged it in truck died. Also the CEL will not illuminate.
But when I leave the MAF off the CEL comes on remains on engine starts. Please advice if I need a new MAF.
1938689
