no spark battle continues
nw montana
now trying to put a
78 ignitor/coil/distributor set up (from running junker)
into my not running, no spark 2F.
problem is that the wiring harnesses are different.
the wiring TO the ignitor consisted of:
a large black wire with yellow stripe that going thru the green connector becomes a yellow wire
and
a medium black wire with yellow stripe that going thru the green connector becomes a light brown wire
the junker showed 12v coming in switched to both of these but when I wire up the same , no spark from coil to ground when turning engine over.
the wiring schematic are confusing
there was a condenser like object coming out of the junkers wiring harness right next to igniter that was grounded to one of the bolts that held the ignitor on , is it needed.
Please somebody help me get this rig running again.
or maybe to simplify my question and dilemma...
if one were to be putting a 78 coil, ignitor, dizzy set up into say a
older 65 or so with incorrect harness....
the hook up would include:
at the ignitor:
brown wire to ????
yellow wire to ????
condensor needed???
lets assume the wiring from ignitor to coil and distributor has been kept intact.
thanks, I thought this would have been kind of easy. but My ego has taken a hard hit today.
thanks for any help.
Both wires should go to the 12v hot from the key. Whatever wire is live when the key is turned to Run and Start from the key switch goes to BOTH those wires in the green connector. One is providing power to the ignitor system; the other supplies power to the + terminal on the coil itself. Last, make SURE you have a good ground on the fender where the ignitor/coil is bolted to the fender.
Maybe Phishtaco can provide a pic of how I wired his ignitor up. Had the same problem with it when we swapped a newer motor/ignition system in his Cruiser.
HTH,
Nick
