No power
I'm trying to fix up my 1971 FJ to serve as my daily driver. Lotsa stuff to tackle, but right now I'm dealing with a power issue.
I've got a 62 chevy 235 engine in it--which seems to run just fine, minus the power issue. My first move is to check the timing. I also believe the carburetor needs replaced. Not to mention, my fj was operated for a long time in Kansas, and is now being operated in Colorado (not sure if the altitude difference would affect performance). Essentially she seems to run great, but just loses total power on long steep inclines. Any thoughts out there?
Hello, I am guessing you meant for this to go in the 40 series section. The 70 series section is a body style, not a decade.
It happens once and awhile, no problems. Welcome to the forum. I will move this thread there.
I have some similar issues with my cruiser....not a daily driver so I kinda deal with it. I need a carb rebuild and I know I have some minor vacuum leaks. Both of these will rob you of power. Also, depending on your altitude, you might need to change the jet size on your carbs due to the fact that the air is thinner up there. Good luck and welcome to the board.:flipoff2:
if your loss of power is only on 'steep' inclines it is likely that your carburetor is the culprit.. I'm not sure how steep of an incline you are talking about but usually this is only an issue durring off-road usage - I'm not a carburetor expert either.. so I could be wrong - if it is as old as your truck it could probably stand a rebuild though..
holley offers this guy http://www.holley.com/types/Truck Avenger.asp
for steep inclines.. though I doubt you have a 4-barrel and I have no idea if it actually performs well..
I am gonna assume that it probably also sports a vintage delco distributor, which may not have had a points service in quite a while.
I once got a heck of a deal on a cruiser with a 235 from a guy who couldn't be bothered to try and check his points before he gave up and sold me the truck for parts. I even offered him $100 more over the phone to try this before I showed up with a tow truck!
Sheesh.
Delco's are crude, but reliable ...........in Cheby motors! Get a new set of points at your local NAPA, find a matchbook cover to gap them with, and see what happens!
Best
Mark A.
Mark A.
My dad did that same thing on his 69 with stock F motor...had an OLD set of points in the glovebox because you just never know, Dive trip ripped his points out and dropped in a new set and gapped with a matchbook cover :lol:
Like Mark said try the points...they should be pretty cheap IIRC
